i need to build some wall cabinets to free up floor space in the new shop. I need about 10 -12 ft of units. probably 15in deep and 18 - 24 high. i have never tried to do this before so I have a raft of questions. i plan on using 3/4 plywood unless there is a reason not to.
What is the best corner joint to use? I have the bits to do lock joints if that’s best.
Should I build individual boxes and link them together or build longer units and put in separators?
If I use 3/4 for construction should the back panels be that thick or something less?
Do you favor rabitting in the shelves or using pins to keep them adjustable.
Anything else I need to consider?
Thanks in advance for your help.
Bill
