Here are some reference charts for most every thing you will be doing out in the shop…
Lumber and wood calculators…
BoardFtCalchart2.pdf (368.7 KB)
this group is for hardware and fasteners… Part 1…
Fastener-Basics.pdf (929.8 KB)
screwchart.pdf (27.6 KB)
Standard Wood Screw Sizes and Predrilling Recommendations.pdf (78.7 KB)
3_Threaded_Inserts_0710.pdf (950.2 KB)
EZLOKBrochure_2014.pdf (1.8 MB)
this group is for hardware and fasteners… Part 2…
TEK_Technical_Guide_.pdf (302.6 KB)
SCREW Type-Chart.pdf (383.9 KB)
¼” Screwdriver Bit Guide.pdf (224.5 KB)
Some information here for what you may encounter drilling…
FORSTNER SPEED&SHARPENING.pdf (107.0 KB)
Drill_Press_Speed_Chart.pdf (529.8 KB)
speedchart.pdf (294.5 KB)
more charts on speed for your tools and bits…
ROUTER SPEEDS-BURNING.pdf (212.1 KB)
here’s a ZIP file for staves…
open it and plug (and play) in your information and your computations will be done for you…
Andy’s Stave Bucket Calculator 2.0.zip (26.0 KB)
plan “B”&“C” to cutting your miters on staves…
no birdsmouth bit??? use your dado blade on your table saw…
the proud on the exterior circumference can either be left, trimmed down some or flushed w/ an LA hand plane or your RT using a sled…
you could vein the exterior joint seam for something different that will make an accent out of any minor flaws…
here’s a link to a convert anything to something…
it’s an incredible collection of calculators and printable tables.
just how fast is that chuck or blade spinning???
Determining Pulley Speeds.pdf (37.1 KB)
just what is that steel that your tooling is made from…
this PDF has additional links to help you know your steels…
Woodworker’s Guide to Tool Steel and Heat Treating.pdf (71.2 KB)
how much extension cord do you need…
no sense starving your tools…
EXTENSION CORD CAPCITIES.pdf (57.4 KB)
Blades…
For the jigsaw…
JIGSAW BLADE GUIDE.pdf (957.9 KB)
For the table and miter saws…
SAW BLADES 101.pdf (280.4 KB)
Table Saw Blades.pdf (857.6 KB)
TOOTH CONFIGURATIONS.pdf (89.2 KB)
Scroll Saws…
ScrollChart.pdf (334.7 KB)
No_Fail_Blade_Chart_206122387.pdf (457.8 KB)
Band Saw…
Band Saw Blades…pdf (89.1 KB)
Recipe for Resawing.pdf (313.5 KB)
Blade Maintenance,
Cleaning Blades and Bits.pdf (194.9 KB)
Note…
When cleaning your blades DO NOT USE Simple Green… It breaks down the Brazing on the teeth… This is per the manufacturer…
I use Dawn Dish Detergent and a stiff nylon brush…
