Many of the ancient Greeks built their famous buildings using the Golden Ratio. Most anything pleasing to the eye more often than not matches the Golden Ratio…
This is also known as the rule of thirds, one third rule, the golden proportion, Fibonacci ratio/sequence…
and…
If you look to Herb’s projects you’ll see that he has this down to a science even though he doesn’t know it… His brain is naturally wired w/ it, while others need to learn it… The projects that look the most pleasing conform to the gauge or are very very close…
Your belt driven tool needs a new belt but what length, or a replacement sheave or pulley… Maybe you’d like to fine tune them up a bit and you need to calculate belt length or gearing…
Perhaps you’d like to know the real output RPM’s of your DP…
