Improve your Drill Press’s table…
A Better Table for a Drill Press.pdf (418.6 KB)
Those are all good ones, I use variations of those jigs too.
10 Easy to build Plywood Accessories for the shop…
This worth while PDF is a wee bit too large (4.9MB) to load…
I will email it to anyone that wood like to have a copy…
I have the how to build plans for this Sloyd Tool Cabinet but the plan is a smidge too large (5.3MB) to load…
I’d be happy to email it to anyone that would like it…
A home for your chisels…
the tip on the drill bit is pretty cool too…
Chisel Cabinet.pdf (516.8 KB)
I have never seen a spade bit like that before, He must have taken a 1" or larger and ground the bevel on each side.
neither have I, it sure is a handy idea…
this router table is a variation of Norm Abram’s infamous router table…
crestonwoodplans.pdf (2.4 MB)
Mr. Abram’s table…
My version of the table…
the larger drawers allow for more storage utilizing less material and hardware…
the stacked design let me use smaller pieces of sheet goods…
See this thread for some RT dust collection ideas…
Router Tables (RT) continued w/ the smaller shop in mind…
One-weekend Router Table.pdf (826.7 KB)
quick-and-easy-router-table.pdf (824.3 KB)
TIPS…
Router Bit Storage….pdf (24.4 KB)
more on RT’s…
if you decide to turn your TS into an RT…
you’ll need a top…
Build an Economy Router Table Top.pdf (177.7 KB)
and the fence to go w/ it…
the-table-saw-router-fence-021415.pdf (1002.9 KB)
Workbenches…
it’s next to impossible to do w/o one or two in the shop…
Moroubian Workbench.pdf (680.9 KB)
Moroubo Woodworking Bench.pdf (950.4 KB)
need a little bit more vise doing those projects???
or you haven’t a vise and having one would be soooo nice…
you like doing dovetails??? these vises are the cat’s meow…
a Moxon bench-top auxiliary vise just may be what is called for…
Moxon Vise.pdf (1.3 MB)
the top glue ups, butcher block style, make for more stable panels and require only pieces… and you get to use up more of your small piece stash…
spline the joints for strength and surface alignment… if you haven’t a thickness planer this will go a long ways w/ initial panel flatness that should only need hand plane touch up…
these vise come in a lot of variations using simplified hardware or if you prefer - exotic…
all thread or carriage bolts, extra large wing nuts, bushings and fender washers - they all work just fine…
here’s one made from OTC constriction lumber…
Tip…
install fitted bushings (aka sleeve bearings) in the rod holes of the sliding faces, makes for a much easier to use longer lasting better performing vise…
just can’t do without them…
and variety is the spice of the shop…
Sanding block plan.pdf (1.9 MB)
Those are great diagrams, one of the most useful tool in the shop.
Great post,Stick. It gives me some new ideas of different shapes.
That reminds me of the machinists’/ tool and die makers tool box. When I worked at Boeing in the late 50’s in the tooling shops all the old timers had one similar to those.
Here’s a plan for a Tambour Tool Cabinet (too large to post 7.75MB) that I will be happy to email to you if you would like a copy…
That is too beautiful to hang in a shop, be great in a store tho.
want me to email you the plan???l…
