Winding sticks are very useful for gauging twist in a board…
Better Winding Sticks-1.pdf (113.6 KB)
here’s a cool saw-bench, step stool and seat…
Saw-bench & Shop Stool.pdf (1.1 MB)
Similar to the one I had, only difference was the “step” was a tool tote and the door slot was a “V” shape to fit different thickness doors. The top had a slot to carry it around. It also served as a seat to eat lunch and have a coffee break.
Later on I put a small Vee block on top to hold small pieces to hand plane them.
stock too long for the TS, DP or joiner???
and each is a different working height but you still need a rest…
there’s gotta be something in this PDF for everybuddy…
Jig Lovers Special.pdf (676.9 KB)
Seems like every project I have to build a jig for it, sometimes a one time jig, others I can use over again. The problem I have is strorage of jigs and remembering what I made it for a year later…
an idea to help keep an odd shape clamped…
Dog-Hole Clamp.pdf (199.2 KB)
write on the jig what it was for…
I keep very very few…
all I keep is drilling jigs, sleds and joint jigs…
need a work bench???..
Simple and Stout Workbench.pdf (2.2 MB)
Best Height for a Workbench.pdf (74.7 KB)
I like everything but the MDF, I would use MDO instead.
https://www.lowes.com/pd/3-4-in-x-4-ft-x-8-ft-Douglas-Fir-Mdo-Plywood/5002104775
I like plywood and hardboard or plywood and the real deal T&G flooring…
hold on!!! to your work that is…
Holding Your Work.pdf (1.3 MB)
Small Parts Vise.pdf (360.7 KB)
get more from your bench vise…
Add a new dog to an old vise.pdf (191.3 KB)
The picture shows the grain going the wrong way, just saying.
that it does…
good catch…
don’t want a full sized TS sled???..
go minimalist…
Minimalist TS Sled for Angled.pdf (163.7 KB)
no bench vise???
this may be what you could use…
instead of bolting it down, use dog holes…
consider using quick clamps or turning the clamps around end for end…
Small parts… no problem…
Thicknessing Jig For Hand Planes.pdf (78.6 KB)
jig for planing super thin parts.pdf (434.3 KB)
jigs to the rescue and to make your doing your project easier…
6 Essential Bench Jigs.pdf (1.9 MB)
box joint…
Basic Box-joint Jig.pdf (379.1 KB)
How to Build a Simple Box-Joint Sled.pdf (1.0 MB)
